hpop is leaking
Old Aug 27, 2007 | 11:46 PM
mybigredford's Avatar
mybigredford
hpop is leaking
i see i have a leak somewhere on the hpop, is there an o-ring kit i can buy or do i have to narrow it down to what is exactly leaking. i have been checking t all day, and so far i think it looks like a line fitting my be the culprit, im gonna try and give it a little crank tighter and see if that helps, it looks like nothing is leaking from the bottom, but i did see a drop on some gold looking thing a ma bop on the back right of the pump, is there an o ring on that thing? allthough it could have ran down from somewhere. also do any of you have a schematic and detailed directions of removal of the pumpof so i can see all the orings.
thanks
Old Aug 29, 2007 | 09:13 AM
jferrar5's Avatar
jferrar5
The gold thing is the IPR or Injection Pump Regulator. Yes it does have a seal kit for it. Mine HPOP leaked and this was the final fix. I also had to change the seals on the high pressur oil lines going into and out-of the pump.
