Sponsored by: Real Truck
Possible oasis report please
Old Aug 27, 2007 | 09:48 PM
daveyo's Avatar
daveyo
I'm really interested in buying this f450 2005 6.0 diesel. is it Possible someone can run a oasis on VIN # 1FDXF46PX5EA26720, any help would be greatly appreciated.
Thanks, David
Old Aug 27, 2007 | 10:23 PM
Beerstalker's Avatar
Beerstalker
Welsome to the site.
We have a thread stickied in the 6.0L forum for Oasis requests. Please post the vin in there or ask a moderator to move your post. Here's a link to the thread.
https://www.ford-trucks.com/forums/6...st-thread.html
Old Aug 28, 2007 | 09:45 AM
BIGKEN's Avatar
BIGKEN
DOB...9/7/04
ISD...3/29/05
6/15/05...Check engine light on/lose throttle response. Replaced EBP sensor.
9/14/06...No crank/no start when hot...long crank when cold. High pressure oil pump fitting leaking.
9/14/06...Exhaust sensor recall/EBP recall
9/14/06...Performed recall 59B01...road test recall
9/14/06...Performed recall 05B32...Degal Bottle recall
9/14/06...Recall 05B27...trans snap ring...r&r Torqueshift and replaced snap ring
That's all folks!!
Old Aug 28, 2007 | 03:33 PM
daveyo's Avatar
daveyo
Thanks beerstalker. BigKen thanks a lot, I'm looking at purchasing this f450 xl it has 35,900 miles 6.0 L automatic 10' ABC dump body what do you think about the Oasis report and they have maintenance recosrds
# Oil Pressure Gauge
# Battery Gauge
# 12 V Powerpoint
# Air Conditioning
# ABS Anti-Lock Brakes
# Power Steering
# Power Brakes
# Gauge Cluster
# Clock
# Trip Odometer
# Tachometer
# Interval Wipers
# Day/Night Lever
# Courtesy Lights
# AM/FM Stereo Radio
# Front Bench Seat
# Passenger Air Bag
# Dual Rear Wheels
# Coolant Temp. Gauge
# Pass. Air Bag On/Off Switch
# Driver's Front Airbag
Old Aug 28, 2007 | 06:56 PM
daveyo's Avatar
daveyo
How about any interpretation of the oasis report, I'm new to Ford diesels and diesels in general.
Thanks for any info.
Old Aug 28, 2007 | 08:16 PM
BIGKEN's Avatar
BIGKEN
The OASIS report tracks warranty repairs on any given vehicle. Among other things that you can find out with OASIS are Date of Manufacturer (DOB), Inservice Date (the date the vehicle was reportes sold...warranty start date), build information (engine, tranny, options, axle ratio, etc.), extended warranty info, color codes, and trim codes. The above example shows 6 warranty related repairs...5 done in one day. Hope this helps!
Old Aug 28, 2007 | 09:19 PM
daveyo's Avatar
daveyo
Thanks for all the info, I also found more specifics on the recalls. Again you have been a great help and thanks.
David
Old Aug 29, 2007 | 12:13 AM
Beerstalker
Looks like a good truck. The high pressure oil pump seal that was replaced was a known issue with the earlier engines. The exhaust back pressure sensor was also a known issue that has since been done away with (one of the recalls that was done). The rest were just recall issues.
Old Aug 29, 2007 | 03:52 PM
daveyo's Avatar
daveyo
Thanks beerstalker, I'm going to take a look and probably make an offer on Thursday, I'm in desperate need for a heavy duty truck. I'm using it obviously for work but I need it for plowing too, so I need it to be dependable. I really appreciate the feedback.
David
