Steering Problem Question
Old Aug 27, 2007 | 12:35 PM
Bullet-Nose's Avatar
Bullet-Nose
The steering box on my 93 F-150 has a major leak. I don't want to fix it because the truck is ready for the junk yard, but want to use until my inspection sticker expires. I've been driving short distances without fluid-how long can do this for, will it cause steering failure?
Old Aug 27, 2007 | 02:23 PM
eco's Avatar
eco
Running dry would be harder on the pump than the steering gear. The pump could seize up on you, and you don't want that! I would disconnect the lines, connect pressure to return, fill the pump up with oil and manually steer (it's not that hard) till it's time to hit the bone yard.
