There was some indication that the upper intake was leaking at the seals, as well as some leakage from a couple injectors and possibly the fuel pressure regulator. I replace all gaskets and seals from intake up as well as the fuel pressure regulator.
Too bad though the mileage has not improved...Ill try an injector clean and a new o2...
try pulling the injectors and soaking them 24hrs in straight Gumout Regane or Techron Concentrate in a glass or metal can... stand them up vertically and add no more than 3/8" to cover tips.
most deposits are external
injector shops charge approx $20 per to ultrasonically clean and test
I just took them out and cleaned them, although I didn't soak them for 24 hours. Externals look good, very clean.
