Sponsored by: Real Truck
Tranny Issues
Old Aug 26, 2007 | 06:24 PM
TheHouse's Avatar
TheHouse
Tranny Issues
Hi guys,
I've got 2004 F250 /w V10 & it seems like I've lost 2nd gear & passing gear.
When it tries to go to 2nd gear all that happens is the revs come up & the tranny seems to slip big time.
It is happening both when under load or even on a flat straight stretch.
I checked the fluid & it's nice & clean /w no burnt smell.
The temp gauge has never gotten past half way.
Does this sound like an electronics problem???
Thanks
Mikey
Old Aug 26, 2007 | 06:45 PM
redford's Avatar
redford
FTE Leadership Emeritus
No, it doesnt sound at all like an electronic problem. How many miles do you have on your transmission?
What do you tow? How much does it weigh?
Old Aug 27, 2007 | 09:57 AM
TheHouse's Avatar
TheHouse
I tow a 24' TT loaded at about 7000 lbs. + 1100 Lbs. on the deck (2 ATV's)
The tranny has never gotten hot according to the temp guage & the fluid looks like new & doesn't smell burnt.
Old Aug 27, 2007 | 10:26 AM
redford's Avatar
redford
I'm no transmission expert, but it sounds like maybe a front pump problem.
Old Aug 27, 2007 | 10:44 AM
michaelmueller's Avatar
michaelmueller
have you changed you're fuel filter latley?
Old Aug 27, 2007 | 10:58 AM
TheHouse's Avatar
TheHouse
No... But it's deffinately a tranny problem.
Old Aug 27, 2007 | 11:04 AM
DavidB's Avatar
DavidB
But, how many miles do you have on it?
Old Aug 27, 2007 | 11:12 AM
TheHouse's Avatar
TheHouse
138,000 KMS / 88,000 Miles
Old Aug 27, 2007 | 11:46 AM
michaelmueller
well, if you are positive it is a tranny issue, with thoes symptoms, I would start with the tranny filter, it is cheap and easy to do and it looks like you are about due for a fluid and filter change anyway. I hope this helps.
I forgot to ask before, does the tranny act the same whether its hot or cold or just when its warm?
gcashs66
Nov 23, 2020 09:09 PM
WB4IUY
Escape & Escape Hybrid
Oct 9, 2014 06:00 AM
hogan_54
1978 - 1996 Big Bronco
Oct 8, 2009 11:06 PM
zach_barrow
Feb 4, 2008 09:10 PM
superdutymj
Aug 19, 2004 12:28 AM
