AC "Max" won't. . .
Old Aug 26, 2007 | 10:18 AM
WayneH's Avatar
WayneH
AC "Max" won't. . .
I understand about the AC setting and the Max setting. For a while now the Max won't work. There is either a vacuum line or a baffle not working. Any thoughts? Hopefully I won't have to be a contortionist to fix it.
The AC works and all other settings work.
Thanks,
Wayne
Old Aug 26, 2007 | 10:32 AM
Neal 97 250's Avatar
Neal 97 250
Do you mean the max a/c won't work at all or is it just not cooling or not blowing on this setting?
Old Aug 26, 2007 | 10:33 AM
Neal 97 250
The only real difference between regular and max settings is that max recirculates the air from inside and the regular is pulling fresh air from outside.
Old Aug 26, 2007 | 10:35 AM
WayneH's Avatar
WayneH
Sorry,
The blower works. But on Max setting the interior air is recurculated rather than fresh air brought in. When you change the selector from AC to Max there is a definate noise level, or used to be. It's not there. The system stays on the AC setting.
Old Aug 26, 2007 | 10:58 AM
Neal 97 250
Max should be recircing and should sound a little different because of that. If it doesn't sound different the flapper that shuts off outside air may be malfunctioning.
Old Aug 26, 2007 | 11:04 AM
WayneH's Avatar
WayneH
Yes, either the baffle/flapper or a vacuum line that controls it. I'm wondering how to check it/fix it.
Old Aug 26, 2007 | 11:27 AM
97REDPSD's Avatar
97REDPSD
ck the white vacuum line its under hood by the evap case.
Old Aug 26, 2007 | 12:08 PM
Cuda_jim's Avatar
Cuda_jim
Take a look here:
https://www.ford-trucks.com/forums/6...wer-speed.html
Old Aug 26, 2007 | 12:09 PM
WayneH's Avatar
WayneH
Excellent,
I had noticed that line was cracked and crumbling. I cut out that part and slipped a slightly larger diameter plastic hose over the ends and secured it with tie wraps. There may be another spot.
Thanks.
Old Aug 26, 2007 | 12:12 PM
WayneH's Avatar
WayneH
Cuda_jim. . .
Excellent also, thanks!
Old Aug 26, 2007 | 01:41 PM
RocknXJ's Avatar
RocknXJ
My '97 is doing the same thing. On regular AC it blows mostly through the vents but some through the defroster. On Max/AC it blows all through the defroster. I figured it's a vacuum issue but haven't checked it out yet. It started a couple of days ago, a day after the gauges were installed.
Old Aug 26, 2007 | 04:33 PM
WayneH's Avatar
WayneH
It was the white vacuum line. . .
When I repaired it last time it had a leak. Re-secured it and it's fixed. Later on I'll replace it.
Thanks loads guys,
Wayne
Old Aug 26, 2007 | 06:29 PM
katbird704's Avatar
katbird704
Mine was blowing on max and none on the other settings. They said that they replaced the blower motor resistor. Now it works. $120 parts and labor
92will
Oct 5, 2016 06:25 AM
1lowF150
Modular V8 (4.6L, 5.4L)
16
Mar 21, 2016 09:07 PM
85F350IDI
Sep 6, 2015 11:16 PM
DitchDoctor
Aug 26, 2015 10:12 PM
Yelrisheam
Sep 27, 2003 09:58 PM
