clutch, trans, or trans problem?
Old Aug 25, 2007 | 04:28 PM
jgib90's Avatar
jgib90
i have a 1978 f-150 351m 4 speed manul trans.4x4, i had just put in a new clutch pressure plat and throwout bearing. had it out in the woods last and its acting like i blew the clutch again i only had it on the road for two days sincethe new clutch was installed. ive adjusted the clutch already and im not get anything still. wondering if any knows if something else could cause the problem? the trans and transfer case shft into gears and four wheel still but it is like no connect between motor and trans. thank you
Old Aug 26, 2007 | 06:42 AM
Ervin's Avatar
Ervin
How did it feel before you went to the woods? And did you go through a lot of mud playing? I would take it all back down and see if it is put together right or if something came loose. Erv
Old Aug 26, 2007 | 03:31 PM
jgib90's Avatar
jgib90
im waiting to get the truck home right so i can take it back apart. one person told it could be the clutch i bought. the clutch felt fine all night then it just stop.
