A Car question?
Old Aug 24, 2007 | 03:28 PM
learpilot's Avatar
learpilot
A Car question?
I realize this is a bit off subject but it's still a Ford, I have restored a 63 galaxie fastback /390 4 speed. It has manual steering so you know how it drives, my question is has anyone heard of a steering box that can be used to make this into power steering like so many here have done using the toyota box? Or maybe you know of a forum that could help with Ford car questions. THANKS for any help
Old Aug 24, 2007 | 04:28 PM
5 Star's Avatar
5 Star
Learpilot
Try this Web Site it deals more of what your probably looking for, good luck on your question.
www.fordbarn.com
Old Aug 24, 2007 | 06:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by 5 Star
Learpilot
www.fordbarn.com
I'd about guarantee they won't be recommending any Toyota parts for retrofit!! That's a die-hard crowd over there.
Old Aug 24, 2007 | 06:35 PM
5 Star's Avatar
5 Star
Ross, on the contrary they are into the modified stuff as well.
Old Aug 24, 2007 | 06:38 PM
CIAF's Avatar
CIAF
Not sure, But, I think www.Jamcosuspension.com is one possible source. plus, I will see Sam of Sam's Vintage Ford at the meet in the AM, he builds these years and I think one has P/S. Will post in PM.
Jon
Old Aug 24, 2007 | 08:43 PM
havi's Avatar
havi
I'll have the Roast Duck
Is it anything like the '62/63 fairlane?
Old Aug 24, 2007 | 11:13 PM
wmjoe1953's Avatar
wmjoe1953
Try www.concoursparts.com They are in Carson City, Nevada, and they have a section on Galaxies, and other big cars. They do have power steering parts for the restorer.
Old Aug 24, 2007 | 11:19 PM
cobraguy's Avatar
cobraguy
I thought power steering was available on the 63 galaxies
Old Aug 25, 2007 | 04:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The steering gear box is the same with or without power steering.
1960/64 Galaxies used a link type power steering.
Contact Mike at Big M in Chico, CA. He should have all the parts to convert to P/S.
You will need: power steering pump and mounting brackets, control valve and ram cylinder, 4 hoses and misc brackets and other pieces.
The 1965 and later Galaxie/LTD's used integral power steering..it won't work in a 1964 or earlier Galaxie.
I presently own 2 1963 Galaxies, and have owned over 20 1963/64's.
Old Aug 25, 2007 | 01:12 PM
learpilot's Avatar
learpilot
Just to clarify a little, I know that PS was an option for the 63 and that it can be added using all the available parts but I wanted to change the steering box to a PS box to do away with the cylinder etc and That's what I am looking for , thanks again
Old Aug 25, 2007 | 01:57 PM
learpilot's Avatar
learpilot
Can you provide more info? phone, web site ?? Thanks
Old Aug 25, 2007 | 02:48 PM
5 Star's Avatar
5 Star
Found this info if it helps.
Big M Automotive
E-mail bigmauto@colusanet.com PH. 530- 473- 2225
Fax 530- 473-5999
271 No. 7th St. Williams , CA 95987 USA
http://www.bigmauto.com/
Old Aug 25, 2007 | 04:52 PM
NumberDummy
First use of integral P/S on full sized Fords = 1965.
The 1965 and later Fords are completely different than the 1960/64's.
How you will be able to adopt this type of gearbox is unknown to me.
What will you use for steering linkage?
Old Sep 17, 2007 | 10:44 AM
CIAF's Avatar
CIAF
OK, I think I know what you want now. There was a car at a show that had an integral box that fit into the stock hole of the 63. Looks like the Saginaw 605 but cast to fit the chassis bolt holes. It came from some Ford enthusiasts known as Gearheads Cruiser Products in ND. you can reach them at 701-223-2269 and www.ndgearheadscruiserproducts.com
I hope this helps you and I hope I understood you correctly. Now if I can just find the PS for my new 63 Falcon droptop I will be set.
Jon
