Check Engine Light ON
Old Aug 24, 2007 | 12:41 PM
levi'sford's Avatar
levi'sford
Driving around today empty and noticed the check engine light on. You can see my mods in my sig. I was running Elites Tow-Power file. Truck seemed to be running fine. Called Elite, they asked if I was towing and if I have the EGR turned off. To my knowledge it is, but I also ordered the Tow file and ended up with the Tow-Power file, which I like, but hope it isn't too much for the truck when pulling. Any way I returned it to stock and checked for codes, nothing. Drove it to work (5miles) and no light, so I put the tune back in, 8 more miles no light. Elite said the EGR delete done with a tuner will throw some engine lights, with no codes??? We will see. Any other ideas? I spoke with Matt at Spartan (impressed), and am planning on doing the unlimited tunes with support when I get back from a 10 day drip in Sept. We are taking the truck, no trailer, so I hope this isn't something bad. Truck seems to be running fine, but was hoping to at least get a code. Thanks guys, and Matt for the info. I am looking forward to your tunes. Thanks, Levi
Old Aug 24, 2007 | 04:46 PM
Maxium4x4's Avatar
Maxium4x4
Did you check for codes before returning to stock? When you flash the truck back to stock it clears the codes.
Old Aug 24, 2007 | 06:05 PM
levi'sford's Avatar
levi'sford
That might explain the no codes. I couldn't find, or get to the menu to check the codes, but when it was back to stock the menu was right there. I may have messed that up. Levi
Old Aug 24, 2007 | 06:42 PM
Maxium4x4's Avatar
Maxium4x4
If a code shows up you can check it out, clear it and see if it returns. Not sure what Tadd told you, I never had a problem like that.
Old Aug 24, 2007 | 07:08 PM
levi'sford's Avatar
levi'sford
Didn't get to talk to Tadd, he was busy. I checked for codes with tune installed. Nothing yet. Thanks for the info. I wandered about setting it back to stock and codes. Now I know. Levi
