Modular V10 (6.8l)
Trans problem
Old Dec 18, 2001 | 11:04 PM
Monsta's Avatar
Monsta
Sit. Stay.
Trans problem
Old Dec 26, 2001 | 10:22 PM
3992824's Avatar
3992824
Trans problem
This morning after I started my Excursion V10 with 4R100 and pulled it out of the garage, the 'off' light on the shift lever started blinking on and off. I know this is not a good thing! The last couple of weeks, I noticed that it didn't shift into OD as readily as it should have, and suspected that something wasn't right. I checked the fluid, and it's not burned, and is on the full mark. I've got 28k on it, and am probably due to have it changed, but I don't think it's overdue.
I had a 46RE go bad on a '97 Dodge Ram with 18k on it. I don't think I'm hard on my trannys. This is starting to give me a complex!
(I posted this on the transmission forum also, but I thought maybe one of you guys may have some experience with this!)
Old Dec 26, 2001 | 10:52 PM
Monsta's Avatar
Monsta
Sit. Stay.
Trans problem
[updated:LAST EDITED ON 26-Dec-01 AT 11:53 PM (EST)]Bummer man... Time to see the dealer, I suspect. They can fire up the old scan tool and cure your poor ailing X. Ya try all those shade tree mechanic tricks, like disconnectin' the battery? Kickin' the tires?
Nice truck, don't chance it. Go see your dealer (or favorite mechanic). As for your fluid, 30K changes recommended. Good luck.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
