Dash Break Light On
Old Aug 23, 2007 | 02:25 PM
chaz3's Avatar
chaz3
Dash Break Light On
2000 EX PSD - Dash Break light is on and i don't know what to look for. the braks still work fine. ABS light is not lit, just the break light. i checked pads and they are fine. fluid resivor is full. will a computer hook-up tell me what is wrong? what should i check for?
thanks
Chaz
Old Aug 23, 2007 | 03:02 PM
ubereal2's Avatar
ubereal2
Smile
Check the brake fluid level. If it's full, take the cap off the resivour and see if the floating switch is floating. If so give it a couple taps, if not that may be you're problem.
Bob
Old Aug 23, 2007 | 03:03 PM
Roody727's Avatar
Roody727
thanks
Chaz
Always check the obvious ... is the E-Brake released?
Old Aug 23, 2007 | 03:18 PM
chaz3's Avatar
chaz3
E-break is released - it's been pushed in released and few times to see if its stuck - seems fine.
Old Aug 23, 2007 | 03:19 PM
chaz3's Avatar
chaz3
i have looked in the resivour, what would the floating switch look like?
Old Aug 24, 2007 | 12:47 AM
wipper's Avatar
wipper
I have the same problem it seem the e break switch is the problem a rubber tip is suppose too hit a push pin (momentary switch)
check if the pinis going all the way up
you can check by looking up under the dash and press the switch with your finger and see if the light goes out
Old Aug 24, 2007 | 08:31 AM
Roody727's Avatar
Roody727
Wipper ... sorry but this was too funny to pass up on a Friday morning .... I hope this is not his issue
Old Aug 24, 2007 | 08:41 AM
vettdvr's Avatar
vettdvr
Just make sure the level is at the full mark. Don't worry about looking for the float switch. It is possible to stick so if it is full a gentle tap might free it up, but I have never had one stick,, so it is possible.
So just fill'er up.
Old Aug 24, 2007 | 08:43 AM
aklim's Avatar
aklim
Give the brakes a flush and check the connectors at the e-brake area to see if they are ok
