I Just Purchased A Used 2001 Navigator About A Month Ago. I Am Having Some Electrical Problems Showing These Symtoms:
Dash/radio Lights Flickering Bright To Dim ,bright To Dim At Random Times - While This Is Happeing You Hear A Clicking Noise Behind The Dashboard
Headlights Will Flicker On And Off Randomly While Driving - Even When The Headlight Switch Is Turned Off.
The Most Unexplainable Is Tonight I Was Standing In My Driveway Talking With A Neighbor And The Navigator Is Parked In The Garage - Not Running - No Key In Ignition - And The Back Tailights Flashed On And Off About Three Times.
I Had The Dealership Hook Up Electric Brakes A Couple Weeks Ago And Started Noticing Some Of These Problems After That. I Took It Back Today And They Checked It Again And Said It Was Not The Electric Brake Hookup Or A Short From That. They Unhooked The Keyless Door Entry Saying That Might Be The Problem If Moisture Got In To That System, To See If Problem Continued. I Had Not Had Any Problem With That So Far.
Can Anyone Narrow Down Or Identify What Is Causing These Issues?
