7.3 questions.
Old Aug 22, 2007 | 08:47 PM
F350-6's Avatar
F350-6
Originally Posted by HKusp
I wish i had actually come up with itmyself. I paraphrased it from a guy on a Ravens chat board. I love it too.
Sorry we've gotten so far off topic but I have to disagree. An unlicensed pharmacist would spend much more time in jail than either a drug dealer or an illegal alien.
Old Aug 23, 2007 | 10:43 AM
Ford ST's Avatar
Ford ST
Right on Gents,
First of all the truck is a F350 CC LB 4x. 8" Donahoe lift with dual Fox's. It is chipped out with the K&N intake and exhaust. 37" with 4.56 gearing. a few other "niceties" are thrown on it.
Great feed back. I belong to the ST1300 site and couldnt say enough bout the riders there. This seems to be the same caliber.
I do have the capability of turbo cool incorporated into the alarm, i will use it.
I have heard the ULSD issue before and will go buy a case and stick it behind the seat.
One question that may come up, after i look into it, with the KN box will other filters fit in it? do they design these suckers to mock the OEM dimensions?
I'll check out the Water separate/fuel filter drain. That is what the Chilton "manual" calls it, but doesnt give a picture. Im on it.
The female thinks i am nuts. I am die hard motorcyclists and December of 05 i deployed to Iraq with MC, where i steadily got shot in Sept 06. I havent been able to ride since, but will soon, so i went and bought myself this truck for a desert toy. I think she was thinking "down payment on a house..." ooops. She was going with the "anything that keeps him off of that bike" logic... we'll see.
Thanks again brothers.
Old Aug 23, 2007 | 11:01 AM
zx250's Avatar
zx250
Of the next Riffraff East
Originally Posted by Ford ST
...........December of 05 i deployed to Iraq with MC, where i steadily got shot in Sept 06.........Thanks again brothers.
No, Thank you Sir. And welcome to the site, Hang around and you will learn all you want to about you truck and what makes it tick. Again, thanks for what you have done for me and our country.
Old Aug 23, 2007 | 11:04 AM
F250_'s Avatar
F250_
Regarding fuel additives.
I've been using Diesel Kleen since last November, nearly 20,000 miles worth, and have kept meticulous records and am **** about to-the-top fillups and accurate hand-calculated mileage. I've also just spent three tanks of running around without the DK so i could get a clean start on a similar evaluation for Stanadyne's performance Formula fuel additive (after all, they're making a heck of a lot of injectors and ought to know something about keeping them clean), and have now just made a half-tank run on the Stanadyne.
Observations: Mileage improvements and much smoother runing engine make it worth it and more than offset the cost of the DK and Stanadyne additives.
Once I stopped using the DK, I noticed my mileage dropping off, and it had settled out at about 1.5 mpg lower after the three tanks of no additive. First tank run on the Stanadyne picked up my mileage by over 1 mpg compared to similar running conditions on the DK (Highway at 75-82 mph with some country roads that, same path traveled many times before). This latest half-tank run got me an mpg calc of 17.2, which is a little higher than I normally see on the same trip path when I've run it in the past at the 75-80mph rate. I can't wait to accumulate a little more data... I have another short road trip tomorrow and then again on Monday as well.
Old Aug 23, 2007 | 11:05 AM
zx250's Avatar
zx250
The water drain valve is on the back side of the fuel bowl, which is located under the plastic Power Stroke cover on top of the engine. Remove the two nuts and move the cover, you will see the fuel filter housing. Lean over and you will see a yellow lever. This is you drain. Just turn it and what ever is in the fuel filter housing will drain out. Might want to put a pan underneth to catch the fuel.
Old Aug 23, 2007 | 01:33 PM
stormyrider's Avatar
stormyrider
If you have been running above 1500 rpm you need a little idle time for turbo coast down so it is stopped before you pull the plug on the oil supply. How long depends on how long you are below this before shutting down. If you pull into a parking lot and keep the rev's down, by the time you are parked you can shut it down. coming off the freeway into a gas station I would give it several mintues to cool of and coast down. A pyrometer gauge on the exhaust would help you determine this.
As for additives, I like the Stanadyne performance formula best but you don't need to add it to every tank of fuel. once a month should keep everything clean. I do like to have it in the tank when towing as it boost the cetane.
I do not like the K&N intake, allows too much dirt through. I installed the AIS intake which is supplied by Ford and gives a 35% improvement in airflow. I own a 200 and the purge valve is on the rear bottom of the fuel filter. Can be fun to see if you don't know where to look. Get something to stand on and look from the passenger side fender at the back of your fuel filter.
Old Aug 23, 2007 | 01:38 PM
Ford ST's Avatar
Ford ST
Right Guys, thanks for the feedback. I belong to the ST1300 forum as well and this seems to be the same caliber folks.
FYI, the 03 is an F350 CC LB 4X, with chip and exhaust mods. 8"Donahoe lift, dual Fox's, mojave tephlons, 37 At's with 4.56 gearing. It has some other creature comforts added to it.
I do have the turbo cool feature incorporated into my alarm, so i guess i will use it when in doubt.
I just went outside to reverify what i thought was a KN intake system, but it appears that it is the OEM box with a KN dropin. I will swap the filter out and have to do some research for a new intake.
The Water separator/fuel boll drain was a piece of cake. It is a rotating lever.
Regarding the fuel adatives, i will pick up a case and set it behind the seat, just so there no excuse.
I appreciate the knowledge with this.. the woman thinks im crazy. I am a die hard motorcyclist and havent been able to ride since March of 06 due to a badly placed sniper round in Iraq. Soo, I bought this truck for a desert toy/hauler. I think she was planning on using that for a down payment on a house... i guess we are getting a smaller house.
Old Aug 23, 2007 | 04:11 PM
Ford ST's Avatar
Ford ST
I see my first post went thru.. Initially when i went to check it out, it didnt show, so forgive the double reply.
Old Aug 23, 2007 | 04:17 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
The yellow handle is the lever for the fuel drain:
Old Aug 23, 2007 | 05:10 PM
Ford ST's Avatar
Ford ST
Right Scott, thanks for the shot.
Old Aug 23, 2007 | 05:12 PM
Texas Outlaw
Not a liberal...
No problem at all. Glad to have you in the club.
Old Aug 24, 2007 | 02:00 PM
Ford ST's Avatar
Ford ST
ZX250* Thanks for the kind words. Here to serve. A man can never have too many scars. (so the therapist says)
Question 27. I read the thread on the wix 6637 and went to the fleetfilter.com site.
http://www.wixfilters.com/filterlookup/PartDetail.asp?Part=46637
The thread i read states that this is a replacement filter. I assume for a stock application. However, the 46637 number is a cylindrical filter, and the filter in the 350 is the planar rectangle type stock looking thingy.
If the 6637 is a replacement for a modified box, can someone reccommend a aftermarket filter for the KN currently in the beast? Also, thoughts on OEM filters? Remember the rig is chiped and exhaust mod'ed.
You Gents have a great one.
jerrol
Old Aug 24, 2007 | 02:44 PM
  #28
zx250's Avatar
zx250
Yep, that's the one. Ain't it great. You have to remove the top part of you OEM filter box and disconnect the rubber intake boot at the filter housing top. Then you reconnect the new 6637 filter in the intake hose and let it lay on the bottom part of the filter housing. I will look for a link with better instruction and maybe get a picture for you.
Old Aug 24, 2007 | 03:35 PM
  #29
zx250's Avatar
zx250
Here's the link and a few pics of my BAF (Big A_ _ Filter) on my rig..
Old Aug 24, 2007 | 04:54 PM
  #30
Action4478's Avatar
Action4478
Can you still shut the hood?.....
