Clearing 37's ?
Old Aug 22, 2007 | 03:12 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
Clearing 37's ?
I'm running a 6" procomp lift with 35's but I'm wanting just a little more tire. Does anyone know if 37's would fit ok with the 6" lift on a 18x9 aftermarket wheel?
Old Aug 22, 2007 | 07:45 PM
WhëëlMå1's Avatar
WhëëlMå1
I think its gonna be tight, no matter what your back spacing is.
Old Aug 22, 2007 | 08:54 PM
DaMole's Avatar
DaMole
I have to agree with rich in that I think it is gonna to be pretty snug in there.
Old Aug 22, 2007 | 09:15 PM
mattd17's Avatar
mattd17
i believe that RIZE industries makes a 8" lift to clear the 37's. since you have the 6" lift on it now, possible you could go with a spacer leveling kit, and larger blocks to get those 2 extra inches..... i wouldnt say its advisable, but it might work. im not sure on the lifts for these trucks, but with the superduties when you cross from the 6" zone to the 8" zone, you tend to get more issues (drive lines, brake lines, etc).
Old Aug 22, 2007 | 09:50 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
Thanks guys, I have add a leafs on the back so I dont think that will be an issue at all its the front that worries me.
Old Aug 22, 2007 | 09:52 PM
WhëëlMå1's Avatar
WhëëlMå1
Same here. Since there is zero lateral movement with the rear tires, you can pretty much stuff those till the cows come home. What are the specs on your current front rims?
Old Aug 22, 2007 | 09:54 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
If I remember right there 18x9s with 110mm backspacing
