Modular V10 (6.8l)
3.73LS vs 4.30LS
Old Mar 22, 2002 | 07:42 PM
Monsta's Avatar
Monsta
Sit. Stay.
3.73LS vs 4.30LS
You put a colon : instead of a period .
See 3.73
It is actually written 3.73:1
Old Mar 23, 2002 | 11:33 AM
NoMo's Avatar
NoMo
Post 3.73LS vs 4.30LS
[updated:LAST EDITED ON 23-Mar-02 AT 12:35 PM (EST)]Wow, talk about some good fuel mileage... 3: 73 gears! ;o)
Old Apr 4, 2002 | 03:12 PM
FatChanceSlim's Avatar
FatChanceSlim
3.73LS vs 4.30LS
[updated:LAST EDITED ON 04-Apr-02 AT 04:14 PM (EST)]Last January, I ordered my 2002 F250 with the V10/6sp. and 4.30LS (it was finally delivered this week, see my gallery). When I ordered the truck, the 3.73LS was not available with this combination. Since I don't do a lot of heavy towing (just pull a 19' boat), I got the 4.30's with the view that I could put on 33" tires or a small lift and 35" tires which would effectively reduce my gearing to "about" the 3.73 level and I would still get the limited slip. I can live with the slightly lower towing capacity in exchange for that setup. And if I don't do the lift/tires, the lower gearing will just help with the performance loss we experience up here at 7400' in the mountains. If you ever are going to consider a lift and/or larger tires, its a no-brainer. The 4.30's just give you more options, IMHO.
Old Apr 4, 2002 | 03:57 PM
ken04's Avatar
ken04
3.73LS vs 4.30LS
I have a question; my 98 E-350 V-10 on the door tag says "34" for the rear axle ratio. But I can't find ANYWHERE that will give me that info. I believe it says "LS" also. Any help ?
Old Apr 9, 2002 | 12:59 AM
hitecdan's Avatar
hitecdan
3.73LS vs 4.30LS
Rumor has it that Ford will be offering a 5-speed auto next year. Any ideas on how this will change the debate on the 3.73 vs. 4.30? Will this new 5 speed have a lower range and top out with the same OD ratio as the 4 speed or will it have a higher OD ratio? In other words, will you be able to get the 4.10 rear end and get similar non-towing highway MPG as the current 4-speed and a 3.73 rear end? Or am I just thinking too much? Future Super Duty buyer wants to know............
Old Apr 9, 2002 | 11:23 AM
kjw84fxr's Avatar
kjw84fxr
3.73LS vs 4.30LS
LittleRadio
Jun 5, 2014 08:46 AM
Andy T
Mar 31, 2007 04:59 PM
jimpal
Feb 3, 2002 03:29 PM
FordRancher
Dec 22, 2001 01:21 AM
X
Mar 27, 2000 02:25 PM
