turbo lag HELP!
Old Aug 21, 2007 | 06:25 PM
justice's Avatar
justice
turbo lag HELP!
I have a 2004 f350 6.0 truck and I have turbo lag issues, or something? help
I put a 6" lift, 37" tires, cold air intake, and 5" exhaust all in a week and I can't tell which of these add-ons made it so the truck will not pick up and go untill the rpms get up. Going down the road about 35 mph or so and I mash on the pedal it seems to do ok, but from a dead stop if I want to step on it it is really sluggish, and will not go untill the turbo kicks in and then goes like a maddog. I do not have a chip and I was wondering if a chip would help or should I change my gears? Or is the 5" exhaust to big(causing less backpressure then would be ideal?) I am lost please help.
Old Aug 21, 2007 | 06:42 PM
dkf's Avatar
dkf
The problem is most likely the 37" tall tires. Are you running stock 3:73 gears? If you are thats more than likely where the lag is coming from. The cure is new gears front and rear 4:30s or 4:56s and about $2000 to do the gear swap.
You could tune it to pick up more power but its sort of a bandaid. Regearing is the way to go.
Old Aug 21, 2007 | 07:10 PM
LvTitan's Avatar
LvTitan
4.56's would be too much gear for that tire, they are good for 40-44" tires.
it is definitely the tires bro. and 37" is kind of a tall tire for a 6" lift.
Old Aug 21, 2007 | 10:15 PM
justice's Avatar
justice
awesome thanks guys, I talked to the guy at the local 4x4 shop and he said it was probibly my 5" exhaust. He said that it wasnt letting me have any backpressure and that it needed some. (I thought diesel's did not have to have backpressure? someone correct me if I am wrong?)
Should I get a chip first? or maybe the Banks High-Ram intake?
what chip is good for this powerstroke?
Old Aug 21, 2007 | 10:24 PM
04Xcursion's Avatar
04Xcursion
Your 4x4 guy is out to lunch.... The 6.0 develops tons of backpressure due the VGT turbo and your 5" exhaust is not affecting low end power at all.
In terms of a chip.... Do a search but the overwhelming majority of us believe that an SCT XCalII with gauges and tunes from a reputable vendor (Matt at Spartan Diesel or Eric at Innovative Diesel are my picks) is the ONLY way to safely tune the 6.0.
Good luck and have fun
Old Aug 21, 2007 | 11:50 PM
LvTitan's Avatar
LvTitan
well that would be the last time i ask that guy for advice. you are correct, he is wrong. the turbo itself is all the backpressure you'll need/want. you want as little restriction as possible behind the turbo.
you already have exhaust, i would do the SCT next before the intake
Old Aug 22, 2007 | 09:05 AM
Deluxe05's Avatar
Deluxe05
As has already been pretty much said, avoid chips/fueling modules, and get an SCT Xcal II with custom tunes from either Spartan or Innovative.
As for air intake, the majority of folks will say to leave it a lone. The stock air intake will support upwards of 500 rear wheel horsepower.
Old Aug 23, 2007 | 05:03 PM
justice's Avatar
justice
can anyone give me a link to a website that sells those SCT Xcal II tuners? (is it like an edge chip? or what is it exactly?)
Old Aug 23, 2007 | 05:13 PM
LvTitan's Avatar
LvTitan
you can get one from matt at spartan diesel, or innovative diesel , or elite, maybe a few others i'm sure.
it is not like an edge juice plug in module. the difference is that a "module" intercepts the factory signals and modifies them before sending them to the inector controller/ecm etc.. it is one way to make extra HP, and they do work quite well, however they do not have any control over the tranny, and they are not custom tunable.
the SCT is a downloader that actually removes the FORD programming from the stock ECM, and REWRITES it with custom tunes. this controls ALL aspects of the vehicle's parameters without any extra hardware being plugged in. basically it is the S#!T
i've had edge modules, and bully dog programming in my truck, and now that i have an SCT, even with a very mild tune, i am way happier. the truck runs like factory except with a lot more get up and go.
when i had the edge, i would notice a lot of "misfiring" (not a correct way of saying it, but you understand how it would run) at partial throttle position. also the edge was responsible for about 3500 dollars worth of tranny work
