you want to run 35's with 9inches of lift? Thats going to look a little funny. I know you want to be taller than your buddy, but it won't make the truck any more capable. Most likely less capable on trails if thats what you do.
I'd rather be a little shorter than the other truck and have a more capable rig. Just something to consider.
I don't know much about that kind of stuff, but over on fullsizebronco . com there is a whole section dedicated to high speed TTB setups. Your f150 uses the same ttb setup as a bronco so there should be plenty of information it there.
I have a 95 F150 4x4 with a 4inch suspention lift and 3 inch body lift. i want it to sit taller and yet be more stable, which lift should i choose for this?
maybe you feel unstable cuz you evidentally are running seven feet of lift...
