Fancy Wiring
I have finally finished the framing in my basement and can start on the wiring. I'm doing basically the same as everyone has talked about.
I had my house built in SLC, so I was able to control most of this from the start. I have at least 2 cable in each room, 2 CAT5 in each, and 2 phone connections in each room. My phone boxes are set up with two connections in the box so that if I needed a secondary phoneline, the top connection will be one and the bottom plug will be another.
Good luck and stay away from the 220. 110 only tickles a little, but 220 can get your attention faster...
This morning I finished up pulling more data/cable into the other jack in the living room. This was a little more interesting of a pull although it was easy since I already had wire running through there to tape onto. Also started nailing up some boxes in the garage so I can have more than 2 outlets in the whole thing.
I took some pictures and I'll try to get those up tonight.
I did the same in my garage.
This last winter I finished rewiring the basement without removing the walls.. just cutting small holes in certain areas and snaking the wire to where it had to go... ..... last week I almost finished the garage.
Tough job doing it myself in my condition ....but I got it done and am now enjoying it.
IIRC, code says ...I think you can have a combination of 12 total ....outlets and fixtures on a 15 amp circuit.
Most undeveloped basements have lights (with string switch) hooked up to upstairs circuits.
That's what I redid last winter.. removed lighting from upstairs circuits and created new circuits through out all 6 rooms.
I can walk the entire basement and have light through out from 4 different circuits and be able to plug something in from either wall opposite to a blow circuit.
BTW, the code book doesn't limit the number of openings that you can have on a circuit, although it is common practice to have 10 openings per 15 amp circuit.
The first ones are of the switches that I moved from around the corner to a more logical spot and tied 3 of the commons lights into one switch. Don't mind the almond switch with the white switch and plate.
Just re-using what we already have. It ended up getting a little busy in the box for the switches, but it is still under the fill capacity.http://mistercmk.com/album/albums/us...2/DSC01668.JPG
http://mistercmk.com/album/albums/us...2/DSC01669.JPG
http://mistercmk.com/album/albums/us...2/DSC01670.JPG
Woo-hoo! This big mess that used to be all the light switches for the basement is finally going away.
http://mistercmk.com/album/albums/us...2/DSC01674.JPG
This is the mess inside some of the light boxes from the old stuff. I still have to get the house drawn up in CAD or at least a rough sketch on a notebook so that I can get my as-builts drawn. I want to try and get everything drawn up and all the wires chased/toned to know where they go before I really dig in.
http://mistercmk.com/album/albums/us...2/DSC01671.JPG
http://mistercmk.com/album/albums/us...2/DSC01672.JPG
http://mistercmk.com/album/albums/us...2/DSC01673.JPG
And finally I finished my desk last night. Picked up some 1/2" MDF for the top and had to lower it down a bit, but the desk is great. Also added a pair of receptacles right at working height (not shown in this pic) for things such as battery chargers, cell phones, etc.
http://mistercmk.com/album/albums/us...2/DSC01699.JPG
This is what the connector looks like.
http://mistercmk.com/album/albums/us...2/DSC01701.JPG
Here is my crimper, I really like the Ideal ratcheting one. It will do RJ45 and RJ11
http://mistercmk.com/album/albums/us...2/DSC01702.JPG
First thing you are going to do is remove about 3/4" to 1" of the outer jacket. This makes it much easier to arrange the wires. I like to use my wire strippers to score the outside and then pull it off.
http://mistercmk.com/album/albums/us...2/DSC01703.JPG
Then arrange the wires in the correct order. I like to use the 568B as it is the most common. The order from left to right is as follows:
W/O, O, W/G, B, W/B, G, W/Br, Br. You will then need to clip the wires down to approximately 1/2" long and make sure that the end is straight.
http://mistercmk.com/album/albums/us...2/DSC01706.JPG
Then put the connector onto your cable making sure that the wires are still in the correct order. Crimp it down with the crimper and then you're done.
http://mistercmk.com/album/albums/us...2/DSC01707.JPG
http://mistercmk.com/album/albums/us...2/DSC01708.JPG
