Modular V10 (6.8l)
cold start popping noise
Old Aug 21, 2007 | 07:38 AM
geraldo14's Avatar
geraldo14
Exclamation cold start popping noise
I have an 02 F250 4X4 with the Triton V-10. Periodically when I start the truck in the morning and it's warming up, I hear a slight popping noise coming from the tail pipe. I had the fuel injection/throttle body service/cleaning performed at my local Ford dealership. It doesn't do this every time I cold start the truck. I wonder if it may be bad gasoline? I sue Chevron 87 octane according to the owners manual this is the octane Ford recommends. the truck only has 38K miles on it and runs great otherwise, any ideas or suggestions on what to check?
Thanks in advance....
Old Aug 21, 2007 | 07:42 AM
redford's Avatar
redford
FTE Leadership Emeritus
Is it a popping noise like expanding metal? If so it might just be the heat shield, which is pretty normal for gassers. Mine does that, plus makes all sorts of popping and snapping noises after I shut it dow.
Old Aug 21, 2007 | 09:49 AM
fderflinger's Avatar
fderflinger
does it sound like it has a slight miss at an idle?
Old Aug 21, 2007 | 10:49 AM
krewat's Avatar
krewat
This would do better in the V10 forum... moved!
Anyway, this sounds like a bad/misfiring COP or plug - or just plain wet/dirty/corroded.
Time to do the plugs/boots and if it's still doing it, start round-robin'ing a brand-new COP to see if it'll go away.
sjwelds
Jan 11, 2015 01:20 AM
trvctyrich
Dec 9, 2011 03:03 PM
topcop5673
1983 - 2012 Ranger & B-Series
Jun 22, 2011 10:06 AM
kenwowski
2004 - 2008 F150
Dec 19, 2008 04:29 AM
grizz5675
Modular V8 (4.6L, 5.4L)
Jan 8, 2004 01:41 AM
