trans fluid question
Old Aug 20, 2007 | 08:59 PM
dayooper's Avatar
dayooper
I am thinking about running amsoil synthetic in my next fast approching transmission fluid change but i have heard you can only run the merc. sp anybody have any insight on this? thanks
Old Aug 20, 2007 | 09:36 PM
4x4Mark's Avatar
4x4Mark
As far as we can tell, Amsoil doesn't meet the requirement for SP - even though they are now stating so. Having said that, the SP appears to be a quality fluid and I can't see switching to something that is both questionable and more costly.
Lets please not make this an Amsoil thread - to date, no one else has licensed Mercon SP and thus Motorcraft is our sole source.
Mark
Old Aug 20, 2007 | 11:13 PM
BC Powerstroke's Avatar
BC Powerstroke
Redline makes D6 synthetic transmission oil claimed equivalent or better than Mercon SP.
I havent purchased any yet as I have not seen the spec sheets yet to verify so I am still using the motorcraft SP.
Old Aug 20, 2007 | 11:32 PM
LvTitan's Avatar
LvTitan
i had my buddy at the tranny shop tell me i could run synthetic, but you do have to remove the converter and cut it open to remove all of the old because you dont want them to mix.
Old Aug 21, 2007 | 12:04 AM
04Xcursion's Avatar
04Xcursion
Mercon SP is a synthetic fluid... I know that it has very specific shear and viscosity characteristics built in to dealt with the abuse this 5R110 sees. As far as I know 4x4Mark is 100% right and until Ford licences out the specs for the oil to other manufacturers I'm going to stick with Mercon SP.
Old Aug 21, 2007 | 02:07 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Mercon SP is synthetic and other companies claims that their fluid is can not be verified, as Ford has not licenced it to others.
As well, the Amsoil stuff claims to be Mercon, Mercon V and Mercon SP rated, but due to the different specs of each fluid, there is NO way it can be!!!!
Stick with Mercon SP from Motorcraft and you will be money ahead... and it is a good fluid at that!!!
Old Aug 21, 2007 | 08:59 PM
dayooper's Avatar
dayooper
thanks for all the good info that is why I came here for advise
