Sponsored by: Real Truck
Hello Everyone
Old Aug 20, 2007 | 06:30 PM
Apache's Avatar
Apache
Hello Everyone
It's been a while since I was last on this website. It's been a difficult time during the last 4 + months.
I'm hoping I can get back online and begin developing some skills in using the computer. I forgot most of what I learned including finding my way around this website. I hope I'm posting this in the right forum.
Best wishes to all.
Jack
Old Aug 20, 2007 | 06:52 PM
yamaguy's Avatar
yamaguy
Welcome back. Your in the right place if your f-250 is the heavy duty one. There is also a 87'-96 fourm and a fourm to go with your engine further down the main fourm page.
Old Aug 20, 2007 | 06:58 PM
njf207's Avatar
njf207
Jack anyone will be glad to help you with finding your way around again. I hope you are doing well not sure what happen but I am sure all of our thoughts were with in the last 4+ months. Good Luck if you need anything Private Message me and I will try to help
Old Aug 21, 2007 | 12:11 AM
Apache's Avatar
Apache
yamaguy,
My truck is a 1997 heavy duty F250 so I'm glad I at least made it to the right forum.
njf207,
I really appreciate your offer of help. I've found everyone very helpful during the short time I've been visiting this website. I hope I can share some of the experiences I've had with my truck in the past.
I've been away dealing with the loss of a second daughter on April 4/07. It's been a rough road to travel.
Thanks for your help and support yamaguy, njf207 and others.
Jack
Old Aug 21, 2007 | 08:08 AM
njf207's Avatar
njf207
Our prayers are with you and your family please if there is anything any of us can do to help in anyway please let us know. God be with you Jack
Old Aug 21, 2007 | 10:05 AM
Apache's Avatar
Apache
Thanks njf207. It's the continuing prayers and support like yours that have helped keep us going.
Jack
Old Aug 21, 2007 | 03:17 PM
njf207's Avatar
njf207
Jack now for some more upbeat talk. Are you having any issues with your truck right now that you need help with.
Old Aug 21, 2007 | 03:27 PM
deltasoft's Avatar
deltasoft
yes we're here to help pal.... best of luck to you and your family......
Old Aug 21, 2007 | 03:52 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Jack, my condolences... and welcome back, although that's a hollow welcome compared to what you've been going through.
You found the right place
Old Aug 21, 2007 | 11:11 PM
Apache's Avatar
Apache
Thanks deltasoft and krewat.
Your comments and support is much needed and appreciated.
Best wishes,
Jack
Old Aug 21, 2007 | 11:33 PM
Apache's Avatar
Apache
Hi njf207,
I started replacing the right front ball joint on my 1997 Heavy Duty F250 and ran into a big problem. I cannot get the spindle off. I've removed the bolts holding the spindle and removed the snap ring, washers, etc on the end of axle. I've tried penetration oil, hitting the spindle with a mallet from side to side and up and down, wedges, a slide hammer, heat, and even built a puller that should do the job. The spindle will not budge!
I've ran into similar problems with my other 4X4s but not as difficult as this. My next approach is to break the ball joints loose and hope they will drop down far enough I can get to them with the cutting torch. If I can get the entire steering knuckle off I can then use a press to remove the spindle. I hope it works because I'm running out of ideas.
Any thoughts you or anyone else may have to share will be much appreciated.
Thanks,
Jack
