Lots of smart folks spend a lot of time on this thread helping to diagnose issues. Thanks to all. So I just had an interesting one and thought I would have some fun with it. I'll give you all the details, take your best shot at a dianosis, and I'll let you know the outcome tomorrow. Should you guess the "next step" that reveals the problem, I'll call an end to it and let you know you figured it out.
Situation: Truck running perfectly, fresh tank of fuel, time for a routine oil change. Changed oil with the usual Rotella (yes, filled filter first). Perfectly normal, nothing out of the ordinary. Oil change complete.
Driving down the road at oil change +5miles and I feel a slight miss. No worries, figure I'm working a little post oil change air through the system.
50 miles later, still there and maybe getting worse. Feels like a dead hole, or maybe half a dead hole. Pretty much only at idle. Presents itself as "rolling miss", i.e. comes and goes pretty regularly, every couple seconds, sometims worse than others.
Note the problem completely goes away above an EOT of 170F.
50 more miles, getting worse, can now be felt while under power at speeds up to 40 mph or so. Still goes away above 170F.
Things checked along the way:
oil level - Fine
Fule filter/flow - fine
HPOP level - Fine
Wiggle Check Harnesses - no change
IPR nut - fine
Engine codes - none
There you go. Give it you best guess (no you don't have to word your answer in the form of a question.
I'll tell you how I diagnossed and fixed it tomorrow.
