fuel drain problem
Old Aug 20, 2007 | 08:41 AM
holiday187's Avatar
holiday187
fuel drain problem
drained the water on a 2000 e-350 van the other day and since then even when i close the drain all the way it still leaks. you can open and close it and it will not leak for a while when you got to start up the next day or after a couple hours itls leaking again out of the drain tube. the longer it runs the faster the leak gets. it's not a steady flow but rather a fast drip.
Old Aug 20, 2007 | 09:12 AM
IDPisan's Avatar
IDPisan
Here is a pretty good thread concerning the leak and the fix, good luck!!
https://www.ford-trucks.com/forums/3...ng-fuel-2.html
Old Aug 21, 2007 | 03:23 PM
holiday187's Avatar
holiday187
took me quite a while to do this on the van but it's done. it really sucks
