Truck won't start! Need help
Old Aug 19, 2007 | 11:49 AM
HawaiianPSD's Avatar
HawaiianPSD
Howzit guyz!
Got a problem and need some help.
After driving 35 miles last night with no probs, my truck sat for 2-3 hours in low 50 high 40 degree weather. Tank was filled up, and recommended amount of DK (gray bottle) added prior to drive. I turned the key and the wait to start light never came on. I cycled the key on/off a few times and still no light, so it made me wonder. Tried cranking it over, cranks just fine but won't fire. Tried cycling a few more time to no avail so, I had it towed early this morning to my local Ford Dealer. Since it's Sunday, the trucks just sitting. Wondering if anyone had this problem before? If so, what was the culprit? Hopefully someone chimes in here quick. Crossing my fingers that it's an easy fix that I can do before Monday morning.
Thanks for any help guyz!!!
Old Aug 19, 2007 | 12:02 PM
Action4478's Avatar
Action4478
Shorted fuel heater,,, May be fuse # 30.......
Old Aug 19, 2007 | 12:04 PM
Benny2002's Avatar
Benny2002
Glow Plug relay? Will a PSD start without at least cycling the glowplugs? Some one will probably chime in with better answer
Old Aug 19, 2007 | 12:46 PM
clintbonnie's Avatar
clintbonnie
Too bad you towed in the dealer.. there is alot of great people here on FTE that can help you fix it.. Sounds like a fuse to me..
Old Aug 19, 2007 | 02:50 PM
guzzle92's Avatar
guzzle92
With no WTS lamp, my bet is on the fuel heater shorted out also. Unplug fuel heater at the bowl, replace 30 amp fuse (do not plug in fuel heater) and if it starts, replace fuel heater.
Old Aug 19, 2007 | 03:05 PM
clintbonnie
Maybe someone can tell you which 30 amp fuse to check..My 99 is different as far as the fuse boxes..
