I can't locate the AC leak i even had Dye shot into the system but i can't see where it's leaking.Is there a common place that they leak.
When i turn on thew rear AC i get warm air but the front is cold,if i did have a leak where would i check first?Could any vacumn hoses cause freon leak?
Why do you think you have a freon leak? the front and back are on the same system. So if you had no refrigerant, the front would be hot too. I suspect you have a problem with your heet/cold temp selection switches or blend door in the left rear quarter panel area.
Check to see if the symptom is the same whether using the front or rear controls (properly).
If the symptom is the same (no control over rear temp using either control):
a. Verify fuse F23 in the underdash fuse panel. If good, the problem may be a faulty auxiliary control module, auxiliary blend actuator, blend door, or other wiring or circuit fault. Possibly even fault thermostatic expansion valve on the rear AC evaporator.
b. If fuse is blown, replace it and see if it holds or not. If not, the short circuit will have to be isolated and corrected.
The diagnostics are not complicated, they primarily involve locating connectors and making resistance or voltage readings.
Steve
I'm curious. What difference does the sunroof make?
