6cyl to v8 conversion
Old Aug 18, 2007 | 11:19 PM
straightsixer's Avatar
straightsixer
Can't help but post all these questions i've had lately.
How easy is a straight 6 to a v8 conversion? Can I use the existing transmission?
Old Aug 19, 2007 | 03:27 AM
Sycostang67's Avatar
Sycostang67
It's not terribly hard. You can retain your current tranny if you stick with a small block V8. The 300 shares the same bellhousing bolt pattern with the 302 and 351W/351C. Most people will tell you a swapping from a 300 to a 302 isn't worth the time/effort. It pretty much depends on your intended use of the truck.
Old Aug 19, 2007 | 04:31 PM
Franklin2's Avatar
Franklin2
Grinding the frame perches off and replacing them with v8 perches is the hardest part.
