Sponsored by: Real Truck
Can't find TS flasher
Old Aug 18, 2007 | 10:53 PM
E-WA's Avatar
E-WA
I have a 05' CC SD 6.0, the turnsignals have quit working and I am guessing its the flasher. I have searched for that square flasher, as per dealers instruction, and am unable to find it, any help?
Old Aug 18, 2007 | 11:34 PM
Workin4ALivin's Avatar
Workin4ALivin
I just had the same problem with mine. no turn signal left or right. Fuse # 27 under the dash was blown. The emergency flashers worked. Check to see if your air vents have defaulted to defrost. The vacuum pump is on the same circuit.
Old Aug 19, 2007 | 01:08 AM
GregsSD's Avatar
GregsSD
The flasher is just behind and above the drivers side glovebox. you can pop out the glovebox and reach in behind it.
Old Aug 20, 2007 | 02:29 PM
E-WA's Avatar
E-WA
Fuse 27 was blown, fixed the blinkers, but the vents start still don't work.
Thanks for the help.
Old Aug 20, 2007 | 08:51 PM
Workin4ALivin
Sorry to tell you this but your Vacuum pump is most likely shot. it is located on the pass side front fender just in front of the fire wall. you should hear it run with the hood up and have someone turn the key to on without starting motor.
