Sponsored by: Auxito
97 ford read end
Old Aug 18, 2007 | 07:36 PM
jeremy067390's Avatar
jeremy067390
97 ford read end
im looking at a 97 f150 that needs a rear. its a dumpy truck used for deliveries. im thinking about buying it spraying it at macco and throwing a light plow at it for a back up... i need to know what rear ends are in these things and what can i expect to pay for one? is it an 8.8 same as the older trucks if so i think i can get one with a aburn from a 94 bronco for cheap but would this fit? can i swap out the internals? also what is a junk yard pull on a 4.6 running now a days
Old Aug 18, 2007 | 07:49 PM
galaxie641's Avatar
galaxie641
If it has the 4.6L or 4.2L it has the 8.8 the 9.75 comes with the 5.4L and is a bolt in. Quite a few earlier Fords used the 8.8, like the CV but I do not know if all the shock mounts line up, I would assume not but could easily be modified. I have no idea what a rear is going for, a guy in another thread found a '97 4.6L for around $1400 with about 50K miles on it.
Old Aug 18, 2007 | 08:11 PM
LxMan1's Avatar
LxMan1
I'm pretty sure it's gonna have to be a 97-99. They bolt pattern is different on 97-newer and the frames are different also. 2000-up will have disc brakes so some other things will be needed there, plus they have larger wheel studs.
Old Aug 19, 2007 | 03:32 AM
duggyb's Avatar
duggyb
what is wrong with the rear-end?...carrier gone? or spyder gears?...if it is all internal than you can pull a carrier or gears from any 8.8 rear end and swap them in.....
THNX
Duggy
Old Aug 19, 2007 | 06:41 AM
ncranchero's Avatar
ncranchero
Here in NC you can pick up a 97-99 F150 8.8 for $350 or less.
Old Aug 19, 2007 | 10:34 AM
jeremy067390
very good pretty much what i expected to hear thanx for the responses. the rear has lots of milage on it. thats why i was hoping to swap it out for a whole new one. but my friend does have a 8.8 built with an auburn. i would just have to re set it up i guess if i wanted to throw it at this truck.
