Brake help
Old Aug 18, 2007 | 04:29 PM
P95Loser's Avatar
P95Loser
Brake help
I just put seafoam in the brake booster line of my 04 f150 and when I was trying to get the brake line off, the fitting that goes into the brake booster popped out and I heard a hissing sound. After that, my brakes are very hard to push in and will hardly stop when I am going 5 miles an hour... what happened and what do I need to do to fix this????
Old Aug 18, 2007 | 06:25 PM
P95Loser's Avatar
P95Loser
update, I just checked and in the process of pouring in the seafoam, the vacuum line got pulled off behind the engine and made it all just fall on the ground. What is the best way to get the brake booster vacuum line back on behind the engine... it's a tight fit between the firewall.
