ok. so i finally got the old 41 1 1/2 ton truck running, but now i can't get her stopped... literally! the brakes are gonna need a complete overhaul! but here's the problem, where do i find brake parts for the old doll. everywhere i've asked, or searched in the net for, has been a bust! any and all help greatly appreciated!
Try this site they may be able to help you or direct you to where you can get the brake parts you need.
www.chuckstrucksllc.com
I looked in my parts book and it goes up to 1 ton only, and according to it some of the cylinders are same as 1/2 ton up to 1 ton.
It could be the same setup, maybe the 1 1/2 ton you have could be rated by the supension itself, as in heavier springs, larger tire size etc.
I'm sure if you took you wheel cylinders to a Napa store they should be able to match it, as well as the master cyl.
Worth a try, it ain't workin now so you have everything to gain.
