Slow Turbo Spool
Old Aug 17, 2007 | 04:44 PM
jambroson's Avatar
jambroson
Slow Turbo Spool
I need some help from you guys. Here is my situation:
I have a 2005 Ford 6.0
I installed a rebuilt Turbo on my vehicle. The rebuilt Turbo is a real dog off the line. Right at the top of first gear it finally spools up and the truck starts moving. I am running an SCT so I went back to the stock setting. Same problem. I did the KAM reset and VGT Relearn and had the same problem. I guess I felt like wasting $250 because I went out and purchased a Turbo Actuator and did the Kam Reset and VGT Relearn again. Same problem. I get plenty of Turbo Boost once kicks in it just takes a while. I am not getting any codes.
Any advice from the professionals?
Also, I have access to a Snap On Diagnostic Tool with the CAN adapter. Does anyone know what readings I should be getting form the turbo?
Thanks in advance for your help.
Josh
2005 Ford F250 Crew Cab, Banks 4" Exhaust, SCT Tuner From Spartan, Quadzilla Commander
1968 Ford 3/4 Ton with a 428 .60 over
Old Aug 17, 2007 | 05:06 PM
LvTitan's Avatar
LvTitan
what transmission are you running ? when you floor it, how long in seconds from the time you mash the pedal till you are around 20psi ?
do you have a boost gauge ?
Old Aug 17, 2007 | 05:22 PM
jambroson's Avatar
jambroson
I have the TorqShift Automatic. It takes about 4 seconds. I have the Quadzilla Commander and I am getting good Boost. I think up to 34 PSI.
Old Aug 17, 2007 | 08:53 PM
BGMSPD's Avatar
BGMSPD
i'm sure one of the resident experts will chime in here but 34psi....that thing should't hit over 30 psi.
Old Aug 17, 2007 | 10:07 PM
LvTitan's Avatar
LvTitan
34 not bad, i could usually run around 32 psi with my stock turbo when i had the edge module on it.
but 4 seconds.. sounds like maybe your vgt nozzles stuck open, which would explain both the long lag, and the high boost.
Old Aug 18, 2007 | 11:41 AM
Danno126's Avatar
Danno126
Check to make sure the Y pipe on the back of the engine is sealed up and isn't cracked.. If it's cracked you should see soot on the engine or firewall..
Old Aug 18, 2007 | 12:49 PM
jambroson's Avatar
jambroson
Y pipe is good. Something is up with this Turbo. It was doing the same thing before and I am wondering if the rebuild was not correct or if something else is going on.
Old Aug 18, 2007 | 12:54 PM
Danno126's Avatar
Danno126
Have you checked the EGR.... Is the SCT a custom tune turning the EGR off? 34 psi is to high... Something is sticking.......hmm
