1978 - 1996 Big Bronco
Transmission- replace with what?
Old Aug 17, 2007 | 03:39 PM
Dutch123's Avatar
Dutch123
Yo!
1. If and when I replace the transmission- sooner than later, E40D, do I simply get a Ford/Motorcraft remanufactured that matches with the 351? Are there any worthy tweaks I should consider - it's my DD
(I understand some online Jasp**sell you an bigger tranny cooler and steel/lines??) What about a new tranfer case?
2. My understanding regarding the warranty is that it will be voided if tranny is not installed by a certified mechanic?
3. No, I will not do this swap myself.
4. My rig has not get up and go- it feels mushy, sluggish almost as if I have not power in the beginning stages of acceleration. Is this transmission related or transfercase?
Old Aug 17, 2007 | 04:39 PM
Kemicalburns's Avatar
Kemicalburns
i would talk with some local tranny shops and also ask some 4wd shops who they would recommend. if it feels slugish perhaps there are other issues. have you pulled codes? when was the motor tuned up last. when was the tranny serviced last? give us more detail regarding the slugishness and we can go from there
Old Aug 17, 2007 | 06:37 PM
runder's Avatar
runder
Factory tech builds an E4OD for gas engines.
http://www.factorytechtransmissions....TS&Category=12
Old Aug 17, 2007 | 06:55 PM
lostin90s's Avatar
lostin90s
One nice thing about going to Ford is warrenty . But $$ but its worth it. Just check local shops and ask people who they recommend. They can build any e4od HD . There are good shops out there. Lately we get ours shipped in .Can't find good shop . I had 3 trans in 68000 miles in last truck . And I had them put the last one in. Good luck
Old Aug 17, 2007 | 09:18 PM
Dutch123's Avatar
Dutch123
I've never had the tranny serviced... I have swapped the ATF twice,, don't know if they checked the screens... so by service, I had the fluids changed twice.. what else does a tranny service contain? Engine compression test was last Aug 06, so, that wasn't really a tune up. Ford mech friend pulled codes April 06...
Old Aug 18, 2007 | 06:34 PM
Dutch123's Avatar
Dutch123
Agghh- double posting- par- don- me.. What should be expected or requested for a full transmissin service?
Old Aug 18, 2007 | 09:07 PM
lostin90s's Avatar
lostin90s
Full sevice or rebuild? A full sevice is draining all fluids ,flushing lines ETC,new filters new fluid .
A rebuild should be to factory spects or better. But I think all the shops around here do the if it works leave it be.
Old Aug 19, 2007 | 10:47 PM
mrknight01's Avatar
mrknight01
All you need is to find a good shop with a good warranty, a lot have 2-3yr now to keep up with the dealers then have then build it with a shift kit. I like trans-co and Superior. Then make sure you get a bigger cooler. Heat will kill a Trans and you can never have one too cool. Fancy converters and controllers or good for high horse power but not needed for any thing with less then 350 horses.
Old Aug 20, 2007 | 12:34 PM
Dutch123's Avatar
Dutch123
The remote tranny filter with guage would be a smart move- I saw a write up. Now, my rig does have a tranny cooler, maybe that can be upgraded?
