Modular V10 (6.8l)
A/C compressor noises
Old Sep 12, 2002 | 09:45 AM
ken04's Avatar
ken04
Yes I ALREADY know I'm ****-retentive,,,, Lately eveytime I haven't run my engine for a while, when I turn on the A/C I get a tremendous clunk, or a clattering noise, it almost sounds like the belt is jumping off the A/C pulley over and over. I recall someone else here asking this same question. Has anyone else had anything similar to this ? I keep having this vision of the compressor freezing up and therefore the serpentine belt shredding into a billion strands and losing all power sterring, alternator, etc, etc. I have even switched the A/C on prior to firing up the beast, and it still makes the noise. Now after it has done this once, it doesn't make any noise whatsoever when I switch the A/C on or off. It's just after it's sat for a day or so. Any similar problems from anyone out there ? We're right @67,000 miles. I went to several other sites including the auto reliability site which lists major problems that a majority of owners have, or have had, and I see nothing like this. Is it just me ? Or do I have a potential problem ? Thanks so much, Ken
98 E-350 XLT V-10 Clubwagon
Old Sep 12, 2002 | 10:28 AM
JKBridges's Avatar
JKBridges
Hey Ken,
I too would like to know if this is a problem. My truck does the same thing intermittantly.
Thanks in advance,
Jeff
Old Sep 12, 2002 | 11:55 AM
CO4x4SD's Avatar
CO4x4SD
Good to hear I'm not the only one. I get a loud clunk sometimes when the A/C is fired up at idle, thought something hit me the first time. I'm betting it is one of those mysterious things that happens that can't be explained.
Old Sep 12, 2002 | 08:39 PM
Monsta's Avatar
Monsta
Sit. Stay.
I would suggest that ya'll go grab yer "thickness guages". I measured my Air Gap and found it out of spec (too close). I still haven't had it fixed yet though...too many kids and no down time welcomed.
The Air Gap is the space between the body of the compressor and the pulley. The manual states that if it clunks when you turn it on, then that's the problem.
I am at my office and do not have my manual here but I will post the specs tonight.
____
What happens to your idle when you turn on your AC? Mine seems to drop a hundred or so. Every other car I've owned, the idle raises when the AC is turned on.
Old Sep 13, 2002 | 10:31 AM
Monsta's Avatar
Monsta
Sit. Stay.
Air Gap.
With feeler gauges, measure three equal areas between the Clutch hub and AC clutch pulley.
The specs call for 0.35 - 0.75 (mm) or 0.014 - 0.030 (in).
If out of tolerance all the mechanic has to do is add or remove spacers depending on the measurement.
Old Sep 13, 2002 | 01:42 PM
ken04's Avatar
ken04
>____
Geez Monsta, you are just THE MAN !! How ever can I thank you enough ? And here I was looking in the penny bank to see if their were funds to pay for another compressor. Wow Ken, you made my day, apprecite ya bro, Ken
Old Sep 13, 2002 | 02:48 PM
Monsta's Avatar
Monsta
Sit. Stay.
A correction to my first post. (Although corrected in my second post but this is for the record. )
The Air Gap is between the Clutch hub and the AC pulley hub and NOT the compressor housing as stated before. Sorry.
Ken, thank you for the kind words!
Old Sep 14, 2002 | 07:01 PM
Monsta's Avatar
Monsta
Sit. Stay.
dieselfumes12
Dec 18, 2012 07:52 PM
CountryBoy685
20
Oct 7, 2011 08:19 AM
Newnan250
Jun 24, 2011 10:05 AM
billybubba
1997 - 2003 F150
Oct 17, 2007 05:07 AM
LV Dan
Jul 19, 2004 11:16 AM
