Sponsored by: Real Truck
Rear panels
Old Aug 17, 2007 | 11:20 AM
chriz501's Avatar
chriz501
Rear panels
Any of you know how to take off the rear panels behind the seat to replace the rear factory speakers?
Thanks
Old Aug 17, 2007 | 12:51 PM
ryaneverk2's Avatar
ryaneverk2
Moving this one to the Super Duty section.
Old Aug 17, 2007 | 01:36 PM
Lonewolftx's Avatar
Lonewolftx
Smile
They just snap in to the pilar. Start at the top or bottom and carefuly pull them out.
Old Aug 18, 2007 | 09:51 AM
chriz501's Avatar
chriz501
Thanks, i'll give that a try.
Old Aug 18, 2007 | 07:51 PM
josh04hdf250's Avatar
josh04hdf250
I had mine out the other day. start at the bottom, middle of the door. Pull the foam door seal up and off all the way to the top middle of the door jamb. You'll need to unbolt the seat belt from teh top of the pillar and let it down. From there, I personally found it easiest to start pulling from the top of the panel. Be sure to pull straight out as you dont want to bend or mangle the clips that hold it in place. It's pretty simple.
Old Aug 18, 2007 | 08:32 PM
mizzitch's Avatar
mizzitch
Is this on a SD? I see you list a 150 in your profile.
while taking the rear pillars off on my crew cab SD I noticed that after pulling all the "snaps" straight out, the whole pillar cover needed to be pushed up toward the roof to get it off... In a 99 SD if I remember correctly.
