P0174 Won't Leave Me Alone!!
"Running lean in bank 2" code has been on in my '01 Reg. Cab F150 with the v6 5spd for probably six months atleast.
new O2 sensors before the cats. new fuel filter. new air filter. new fuel injectors and new MAF sensor.
Just got it out of the shop and two days later it came back to haunt me!
Any help would be GREATLY appreciated
This one was haunting me too. I finally found my solution yesterday. A vacuum leak. It was the rubber elbow on the passenger side intake runner, right near the firewall. It connected to intake air heater - hard to see and reach. A quick fix - if you have some old plug wires (distributor type), you can pull off one of the ends that snaps into the distributor. The resulting little elbow is the perfect fit.
I looked and looked for this leak - finally the little piece deteriorated enough that I could actually hear it leaking.. No more 0174s!!
