fluid leak rumble sound
Old Aug 16, 2007 | 09:20 PM
PoPs 03DEX's Avatar
PoPs 03DEX
Unhappy fluid leak rumble sound
Two items.
Oil is leaking. Just returned from a trip between San Francisco & LA Drip is evident between the engine & transmission. When parked maybe 3 to 6 drops, the underside is dotted and the rear doors and glass have very fine oil spots. Have 68K miles cannot see any differernce in the engine or transmission dip stick levels. From what I can see in the engine compartment no obvious sign of leak.
Noticed the turbo air hoses at connection points have slight oily film. any thoughts on what or where this may be from?
Also have a sound when letting off the accelerator abruptly under moderate to heavy acceleration. Is this transmission or related? Sounds like a mild metal rumble?
If not will need to pay the 'C' note to the dealer 2003 6.0 PSD Excursion.
Will be back Sunday Thanks in advance
Old Nov 6, 2007 | 08:46 PM
danieltrekker's Avatar
danieltrekker
Oil leak grown to hemorage!!!
hope someone knows where this oil leak comeing from. I have same problem,started as afew drops, has become a serious hemorage. Have heard of plugs on top of block or turbo oiler return line. Help don't want to go to dealer,don't trust them. LUV the TRUCK 03 6.0 Good runner pulls with true authority!!!
