Door Weather Strips
Old Aug 16, 2007 | 08:37 PM
FORD4X476's Avatar
FORD4X476
Door Weather Strips
hello, am restoring a 76 ford f100 and painted so i ordered all the weather strips for the pick up from LMC. the guy who painted it installed the door weather strips but the door does not close properly. it closes but not all the way. what do you all recommend
Old Aug 16, 2007 | 09:33 PM
BigGrizz76's Avatar
BigGrizz76
R U sure it's the weather strips? Maybe your hinges are sagging, or maybe the door needs to be tightened to the pillar. Just some thoughts.
Old Aug 16, 2007 | 09:59 PM
rboeding's Avatar
rboeding
Sometimes it takes a little while for the new rubber to compress and actually allow the door to close properly - also get a new set of pins from the help section at AZ or other with the plastic cover - makes alot of difference.
Old Aug 17, 2007 | 12:24 PM
Mil1ion's Avatar
Mil1ion
All weatherstripping will be puffy at installation but from what hear the stuff LMC sells is the worst.
Only after years of having the doors closed and climatic conditions prevail, the W/S will be closer to normal.
Old Aug 17, 2007 | 06:03 PM
One79one71's Avatar
One79one71
Whats a better source for it then?
Ford4x476, did the door close better before?
Old Aug 18, 2007 | 11:30 PM
FORD4X476's Avatar
FORD4X476
yes, it closed right before.
Old Aug 19, 2007 | 12:38 AM
Mil1ion's Avatar
Mil1ion
That's because they were old.
