boost experiment
Old Aug 16, 2007 | 05:48 PM
f100guy's Avatar
f100guy
boost experiment
i want to try to rig up a 200 mph leaf blower to the induction on my 85 6.9 and put a pressure gauge on the filter housing to read. i am curious to see how many psi it will make. i know this is a controversal topic, but 200 mph wind has to do something in the way of boost. anybody have any ideas. i have seen a pic online of a mustang with a leafblower under the hood. it looks pretty funny.
Old Aug 16, 2007 | 05:52 PM
dwaymar's Avatar
dwaymar
just think if it don't work at least your drive will stay free of leafs
Old Aug 16, 2007 | 06:43 PM
crazymike's Avatar
crazymike
sounds like a good idea. if it generates any power i'd like to know
Old Aug 16, 2007 | 07:11 PM
Dave Sponaugle's Avatar
Dave Sponaugle
As an experiment, block the end of the leaf blower tube off and rig a pressure gauge to read tube pressure.
My guess is you will build very little pressure or none at all.
Figuring cubic inches and the displacement of a 6.9, if you ran the engine at 3300 RPM and tried to suck all the air through a 1" x 3" slot like you have at the end of a leaf blower tube, I figure 218.75 MPH for the air velocity at the slot.
To build 7 PSI you would have to have an air velocity over 328.125 MPH through a 1" x 3" hole at 3300 RPM.
A large ram air will probably build more pressure and be much easier and cheaper to construct.
Old Aug 16, 2007 | 07:59 PM
RunRed's Avatar
RunRed
You know, if you had a V8... I wonder how it would work if you made 4 cylinders into air compressors that fed the other 4 cylinders.... I mean if you could get the timing right to where it would run.. I wonder if it would do any good..
Old Aug 16, 2007 | 08:09 PM
Brimmstone's Avatar
Brimmstone
That has been done for decades but for a different reason. We used to take old V-8s and convert them into four-cylinder gas engines with four-cylinders being used as an air-compressor. There is also a kit to convert a VW flat four into a two cylinder engine with two cylinders working as an air-compressor. Never thought of having the air driven into the engine. I think for the amount of drag you would have it wouldn't be enough of an improvement.
Old Aug 16, 2007 | 09:51 PM
69-highboy's Avatar
69-highboy
Obviously the answer is dual leaf blowers
Couldn't resist, sorry...
Old Aug 17, 2007 | 08:28 AM
f100guy's Avatar
f100guy
what if i was able to get my hands on a turbo, take the exhaust side off and weld a pulley to it. would the belts spin it fast enough to make any boost. what kind of pulley would i need in size.
Old Aug 17, 2007 | 03:01 PM
zigzkidz's Avatar
zigzkidz
i thought of that before i was going to do it but i didnt, i brings a whole new meaning to forced air intake
Old Aug 17, 2007 | 03:22 PM
69-highboy's Avatar
69-highboy
Seriousely, they do it all the time -it's called supercharging. Forget the pulley idea, it won't work. Superchargers were of two primary types: centrifugal, like a turbo, and roots, like those found on Detroit Diesel engines. Just for grins look up Paxton superchargers.
Old Aug 17, 2007 | 05:26 PM
f100guy's Avatar
f100guy
i know about those but i am wanting to do a homemade thing. there is a turbo at the shop from a 466 international. i was thinking of putting it under the truck how much lag would i expect. the truck has a granny 4 spd tranny.
Old Aug 17, 2007 | 06:59 PM
69-highboy's Avatar
69-highboy
Exhaust driven turbos turn up to 100,000 RPM or more, so the pulley idea is an impossibility. You'd need a much larger unit with a different shaped impeller to work, and more likely than not, some kind of planetary gear drive to rotate the unit at the speeds necessary to generate induction pressure.
Your reinventing the wheel, but have fun!
Old Aug 17, 2007 | 09:24 PM
Dave Sponaugle
Given the speeds the impellers turn, balance, material strength, tolerances, heat build up and a host of other things need to be worked out.
Not something that most people have the equipment or knowledge to produce, even more so in their garage for a limited budget.
If a turbo impeller turning 100,000 RPM exploded, we are talking serious personal injury or death as a very real possibility in the event of a failure.
Fragmentation grenade....turbo impeller failure at high RPM.
The results of both are the same.
Small pieces of metal traveling at very high speeds in all directions.
Remember, you only have a layer of thin sheet metal and a couple layers of plastic between the passenger compartment and the engine compartment.
Old Aug 20, 2007 | 10:02 AM
f100guy's Avatar
f100guy
how much boost can an 85 6.9 handle without getting head studs.
Old Aug 20, 2007 | 10:48 AM
F250FarmBoy's Avatar
F250FarmBoy
A little over 10 lbs, so I've heard.
