hard to start
Old Aug 16, 2007 | 01:49 PM
KSTTAC's Avatar
KSTTAC
hard to start
1989 f259 460 efi. done full tune up, runs great. however from time ti time it is really hard to start, like its not getting fuel....any ideas? once it starts it runs fine.
Old Aug 16, 2007 | 04:52 PM
mcdonaldm's Avatar
mcdonaldm
cold start circuit not working so it might not be getting enough fuel (efi's version of a carbs choke) at start-up?
as for how to check it, no idea. sorry.
one idea.
rgds
Mike
Old Aug 16, 2007 | 10:33 PM
stngh8r's Avatar
stngh8r
Mine is only hard to start when its warm???? And really hard to start if its quite hot?? If cold, it fires right up??
Old Aug 17, 2007 | 12:03 AM
darrin1999's Avatar
darrin1999
could be the idle air control valve sticking in both cases. if it sticks when cold its probably carboned up, if it sticks when hot it could be gummed up with something else, or the valve just doesnt want to actuate. theres a pretty limited number of parts that control the starting of efi. another thing that could make it not want to start when warm is if your exhaust runs right next to the starter- could heat up the brushes in it and make the motor not want to turn. could be crappy cables- as heat goes up resistance goes up.
Old Aug 17, 2007 | 09:05 AM
stngh8r's Avatar
stngh8r
ThanksDarrin
Old Aug 20, 2007 | 08:22 AM
KSTTAC's Avatar
KSTTAC
replaced the air control valve...still does it ....any other ideas?
Old Aug 20, 2007 | 08:23 AM
KSTTAC's Avatar
KSTTAC
also it turns over fine, just wont start until it turns over for about 10 seconds
Old Aug 20, 2007 | 05:01 PM
darrin1999's Avatar
darrin1999
did you check your fuel pressure? maybe the regulator isnt working right. did you change the fuel filter? have a new air filter?
Old Aug 24, 2007 | 09:21 PM
flguy's Avatar
flguy
Have 1989 4.9l. Just in the last few weeks, hard start when warmed up. Acts like the battery is going dead. Will hardly turn over. Turns over/starts fine when cold. Has new air control valve. Any suggestions? Battery connections clean, alt charging fine, battery in good condition.
