Wierd idle
Old Aug 15, 2007 | 09:34 PM
gtsom6's Avatar
gtsom6
Wierd idle
First post here guys, have found alot of usefull info. Every now and again my truck idles wierd, shakes and sounds like it's loping. But I can turn it off and start it back up and idles and runs fine. Any ideas what sensor or something could be the problem. I've done the 10k mod and shimmed the fpr.
Old Aug 15, 2007 | 10:36 PM
bkcowboss's Avatar
bkcowboss
Is your truck a manual transmission, if so does depressing the clutch, or releasing the clutch quickly cause or eliminate the problem?
Old Aug 16, 2007 | 04:54 PM
Neal 97 250's Avatar
Neal 97 250
10K does cuse rough idle from time to time. Did it do it before you did that?
Old Aug 16, 2007 | 04:55 PM
Neal 97 250
BTW I forgot Welcome to FTE post happy and post often. My motto anyway.
Old Aug 16, 2007 | 05:07 PM
Action4478's Avatar
Action4478
To start out,,,,Check the connection to the ICP & make sure it is not loose ,corroded Or leaking oil.....Unplug the ICP when at rough idle & see if it smoothes out....
Old Aug 16, 2007 | 05:39 PM
Suber's Avatar
Suber
There is always going to be a "Phantom" idle from time to time it appears. I think everyone on here has had it at one time. It could be your oil.
Old Aug 18, 2007 | 12:51 PM
gtsom6's Avatar
gtsom6
Thanks for the replies. I will have to check everything and try unplugging the icp. I know it is probably just going to be this way, just wondering if it was something to worry about.
