headers (again)
Old Aug 15, 2007 | 08:14 AM
Flyn66dtmn's Avatar
Flyn66dtmn
headers (again)
I took the tag off the third member last night and was surprised that it was still readable. here's the numbers off the tag maybe someone can decode them for me.WBG-H2 3-39 4CB 304 the B on the 4CB was pretty beat up so it could posssibly be a 2. also does anyone know how many years a person could interchange parts on he I6's. they still run the 300's but the castings have changed over the years and a lot of the newer parts wont bolt up to to the older 300's. As far as the 16 mpg goes i was just guessing. i have never actually tested it. i do know that it gets better than twice the mileage my 390 gets. the 64 4WD is pretty much wound up at 60 mph. thanks Dutch
Old Aug 15, 2007 | 09:09 AM
cobraguy's Avatar
cobraguy
Dutch are you sure thats not a 3-89 on the tag. If your wound pretty tight at 60 and it being a 4x4 a higher ratio number would make sense. Common numbers I've seen are 3.70, 3.89, 4.10. Some body will be along shortly to decode your axle tag. As a suggestion you could change the subject of your thread to decode axle tag or something like that. I looked at your thread and thought more header questions then was surprised to find an axle question.
Old Aug 15, 2007 | 09:53 AM
Flyn66dtmn's Avatar
Flyn66dtmn
it very easily could be a 3.89 gear ratio. the tag wasn't in to good of shape. Dutch
