Greetings all! (again)
In the insulation under the hood I found the production form:
B&A-8502-T May 1989
Which has the Ford codes for the various components such as:
Engine 9G002BA;
Transmission FOTP WA;
Rear Axel 129C; and
so forth.
Does anyone know where I can find out if those have equivalents that relate to parts or component manuals (for the rear axel/differential ratio as an example)?
I know the first thing I need to do is replace all fluids and filters, and drain the fuel/water separator.
Also, this may be a dumb question but: for the fuel tank selector switch - which way is for which tank? Up for front - down for rear or vice versa?
Thanks,
Don
1990 F-250 XLT Lariat 7.3 diesel
Don, click on the Forums tab at the upper left and look over the boards. You will find a lot info in them they are sorted by the application. Check them out and you'll have yours running just the way you want.
Good luck!
