'85 351w plus SD EFI
Old Aug 14, 2007 | 04:58 PM
bennyd's Avatar
bennyd
I'm planning on swapping the worn-out 5.8 in my '91 F250 with a recently rebuilt long block from an '85 truck (carbed, of course).
Will the '85 cam mess with the '91 SD 'puter? Any other suggestions or advice?
-Ben
Old Aug 14, 2007 | 05:10 PM
87f1504x42001's Avatar
87f1504x42001
my uncle converted a 302 fuel injected to carburetor. and his truck wouldnt start, they unplugged the computer and it started right up. dont know why, but, it might be the same as far as your truck goes
Old Aug 16, 2007 | 01:29 PM
bennyd's Avatar
bennyd
What should I be sure to pull from my '91 block? Sensors & dizzy for sure, but will anything else give me trouble? Do I need to swap the cam?
Old Aug 16, 2007 | 03:01 PM
Conanski's Avatar
Conanski
Was the '85 a HO motor? If it was use the cam it has. If not swap it out for an aftermarket cam, the standard cam for the non HO 351(both EFI and carb) is lame. You'll need the complete EFI intake with all wiring and plumbing for the swap.
Old Aug 16, 2007 | 11:05 PM
albung's Avatar
albung
you are just changing motor thatis carbed to ur truck with sd efi correct??? mite work with the cam mite not depends on lobe seperation
Old Dec 10, 2007 | 05:36 PM
bennyd's Avatar
bennyd
Just now getting around to the swap... :P
Yeah, the air cleaner shows that it's an HO, so I'll leave the cam in. Looks like I'm going to have to swap the timing cover too, the old one had a cam-driven fuel pump.
Thanks all...
Old Dec 10, 2007 | 10:21 PM
Conanski's Avatar
Conanski
Blockoff plates are available to cap the timing cover....
Old Dec 12, 2007 | 03:05 PM
bennyd's Avatar
bennyd
Too late, I already replaced mine... I've got both blocks side-by-side and I'm just moving most of my 91's gear over to the '86 block. Thanks for the tip though
How much better is the '86 HO's cam? Am I gonna need to chip my ECM after I get done, or should it run ok?
Old Dec 12, 2007 | 09:45 PM
Conanski's Avatar
Conanski
I think it'll run fine, and it'll produce WAY more power than the '91.
Old Dec 13, 2007 | 12:42 PM
bennyd's Avatar
bennyd
Nice... you just made my day!
Just keep your fingers crossed that my poor little SD computer doesn't get too confused, I don't want to buy a chip for it ($$$).
fordka
Ford Truck Parts for Sale
Oct 29, 2016 02:27 PM
fordka
Sep 4, 2016 11:22 AM
Painted-horse
Mar 13, 2015 06:01 PM
scrapyardking
Nov 27, 2008 09:48 PM
ctvanover
Jan 2, 2007 12:27 AM
