302 won't start
Old Aug 14, 2007 | 07:46 AM
woodly1069's Avatar
woodly1069
302 won't start
Does anyone know why I may not be able to start my truck without the air of starting fluid in the intake tube. After it gets going it seems fine...doesn't miss a lick! I'm clueless
Old Aug 14, 2007 | 08:51 AM
subford's Avatar
subford
Try turning the key off and on about four times before you try to start it.
You fuel manifold does not have any fuel in it after setting. You have a bad check valve or maybe a bad fuel pressure regulator in your fuel system.
Old Aug 14, 2007 | 11:15 AM
specialist484's Avatar
specialist484
definitely a fuel problem. Check fuel pressure. Do what Subford said, and if that doesn't work, change fuel filter.
