I have asked this question in passing before, but now I am reaching critical mass. I need a 3 groove lower pulley, a power steering pump and bracket and the triangular mount for the alternator. 351-C of course, if anyone can help, please let know, I've not had any luck at the local wrecking yards. Thanks
Tim, I have some of the items you mentioned, but they are for a 289/ 302/351W. Not sure if any of those parts work on a 351C. I don't have the power steering pump but I believe I have a 3 belt lower pulley which came off a 66 Mustang with the smog pump, and I have the triangular alternator bracket which mounts on the water pump. Let me know if they fit a 351C? Check this out also: http://cgi.ebay.com/ebaymotors/69-70...spagenameZWDVW
I am in the same boat. I need pulleys, brackets, etc, too. I haven't even started looking for them in the junk yards, but i figured to scrounge stuff off of a 400 in some old station wagon or full size Ford. I understand they will work on the 351C, as the blocks are basically the same.
