Ideas For Engine Mounts
Old Aug 13, 2007 | 11:14 PM
1957F100's Avatar
1957F100
Ive got a 57 with MII suspension. Im putting a 302 and C4 in the truck so im going to need to fab up some engine mounts. Thats not the part im having trouble with...the part im finding hard is figuring out where i need to put the mounts on the frame! Ive got a tranny mount bolted to the tranny and its sitting in the frame. Then ive got the engine held up by a engine hoist. Ive got the rad support bolted to the frame and im just about to put the cab on. Then im going to move the engine back and forth until i get it to clear the firewall and rad support. Then im going to have to tilt the engine until i get it right. If i put a compass on the top of the intake it should be at 0 degrees and if i put it on the front by the water pump it shoulld be at 3 degrees right?. Im pretty sure thats what ive heard somewhere before.
This is my first time doing this so im pretty much just asking all you guys if ive got this planned out right and im also hoping some of you out there with the same setup as me have some pics so i can get some ideas and point me in the right direction. Thanks
Old Aug 13, 2007 | 11:27 PM
51dueller's Avatar
51dueller
You want the intake close to level. I never heard of the water pump measurement before. Just get the engine to fit the best under the hood and weld the mounts in.
Old Aug 14, 2007 | 12:41 AM
Col Flashman's Avatar
Col Flashman
You get Better performance out of an original 312 Y-block, you'd not have to worry about clearences or welding anything as it already fits nicely & they make adaptors to mount a C-4 to them.
Old Aug 14, 2007 | 06:56 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I mounted mine the same way you are approaching yours. Use the top of the intake manifold to level the engine side to side and front to rear. Be sure before you start leveling the engine that the truck is perfectly level. I had to put 2x4s under the front tires to make my truck level before I started the engine leveling process since I had smaller tires on the front at the time.
Old Aug 14, 2007 | 10:07 PM
brucewolff's Avatar
brucewolff
Originally Posted by GreatNorthWoods
....Be sure before you start leveling the engine that the truck is perfectly level. ......
Well, that's true only if your truck is level when at ride height. What you really want to do is set your frame at the desired ride height and level side to side. Then set your engine's up so the intake manifold surface is level in both directions.
Old Aug 14, 2007 | 10:26 PM
havi's Avatar
havi
I'll have the Roast Duck
Right, I was gonna say that the final "rake" is a factor, too. So to add to this, does anyone know the degrees of the top of the frame at the steering box (only as a reference pt.) on a stock truck? I don't have my front suspension on the truck yet, the PO drove the kingpin bushings into the spindles so mounting them is out of the question, other parts are still missing, and I want to get everything lined up before sandblasting/painting the frame, so I'm not at stock height, but would like to be before I set the engine mounts in. I think knowing the angle would help, as I can tweak it from there. IIRC, I measured 4 degrees with the 9" rear on, and the front beam on a dolly.
Old Aug 14, 2007 | 10:35 PM
rswhitmore's Avatar
rswhitmore
I would like to respectflly disagree with you on the 312 vs 302 performance. I have a 48 F1 with a built 306 in the 375-400 HP range with a T-5 5 speed manual transmission, and I have never personally seen an original 312 that would come close to it.
Old Aug 14, 2007 | 10:40 PM
Col Flashman
That's you Personally, I've seen Built 312's w/ ALL the T-Bird Performance parts added on & Stomp built 302's till the cows come home.
Old Aug 15, 2007 | 08:52 AM
GreatNorthWoods
Bruce,
I respectively disagree. Unless you will have a severe rake in your final stance IMOHO it is better to level the truck to set mounts. You may change your tire and wheel setup many times during the life of the truck and you only want to do engine mounts once. A few degress of rake due to big and little tires or a lower front than rear suspension will not be a problem if the truck is leveled prior to setting mounts...
Old Aug 15, 2007 | 05:07 PM
havi's Avatar
havi
So is the frame level when stock?, or is there a slight forward drop?
Old Aug 15, 2007 | 05:19 PM
houghda's Avatar
houghda
Level Later
I have not done this on an Effie (I am the Explorer guy) but I have on a 55 Chevy Wagon. Remember that you will only need to be close to level because the tranny can be raised or lowered to move you a couple degrees each way.
Your mounts will have play in them
I BOLTED in my mounts then checked everything over and over,,,,steering box clearance (depending on your steering system), oil pan, etc.
Then I tack welded it and checked everything again, on different days!
also, ensure it is straight front to back, side to side. (obvious)
Are you using one of those aftermarket 'tube' mounts?
Old Aug 15, 2007 | 07:17 PM
brucewolff's Avatar
brucewolff
Bruce,
OK.....but if you know what your ride height or rake is going to be why would you level the frame instead You would automatically be off unless your rake is level.
Old Aug 16, 2007 | 06:51 AM
GreatNorthWoods
If you knew for a fact that the stance would never be changed in the future then you should set the mounts with the current rake considered. But, as we all know these old trucks are a constant work in progress and what we do to them today may not be what we want a year from now. You might want a different rake later due to a different set of tires or suspension changes. I'm just saying if you level the truck now then those kind of changes later will not be a significant factor.
Old Aug 16, 2007 | 09:48 AM
create's Avatar
create
i had my frame level when i leveled my intake to create my engine mounts. But I plan on having it that way with no huge rake.
I have an MII with a 302/c4 combo as well. I had to buy a ford racing pan /oil pickup to be able to clear the MII crossmember.
Old Aug 16, 2007 | 08:47 PM
havi's Avatar
havi
wow, that's a lot of room for a supercharger/blower, lol
