proporting valve
Old Aug 13, 2007 | 10:04 PM
joe black's Avatar
joe black
proporting valve
have installed power brake kit and am ready to run the brake lines. my question is about front brake lines. does it make any difference which line goes where in the front. i know the back hook up is right but unsure of front lines
Old Aug 13, 2007 | 11:13 PM
CharlieLed's Avatar
CharlieLed
All depends on whether you are running disk/disk or disk/drum or drum/drum and whether you have the MC below the floor. You should be running the appropriate proportioning valve and residual valves (if the MC is mounted under the floor). Most of the brakes vendors have good diagrams on their websites that you can refer to.
Old Aug 13, 2007 | 11:24 PM
49fordpickumup's Avatar
49fordpickumup
brake lines
On the ones I have done: If you are on the left side facing the proportioning valve, the bottom line goes to the left front brake and the top line goes to the right front. I don't know if it really makes a difference. The car or truck your valve was made for should describe installation directions. Bleed rr,lr,rf,lf sequence.I use DOT 5 brake fluid. Have a great day chuck
Old Aug 14, 2007 | 02:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford basic part number: 2B257 ~ Brake Pressure Differential Proportioning Valve
Ford cars and trucks from 1967: Mounted on the left frame rail inboard of the left front wheel.
