low range on 94 ranger
Old Aug 13, 2007 | 09:52 PM
ricoh5's Avatar
ricoh5
electric 4wd wont engage when i press low range switch, works fine on hi range . has anyone had this problem b4 ? what can i do to fix?
Old Aug 19, 2007 | 10:15 PM
cddz's Avatar
cddz
Do you have it in park or nuetral when trying to put it in low range? If you don't it needs to be
Old Aug 20, 2007 | 06:19 AM
Rags's Avatar
Rags
On My 94 Auto the trans has to be in nuetral and my foot has to be on the brakes. Make sure your brake light switch is working. I think it is part of the loop to engage 4low
Old Aug 21, 2007 | 11:59 AM
ricoh5's Avatar
ricoh5
Thumbs up thanks
ive tried it both in park and in neutral and it wont engage ive tried it at low speed. still nothing. but thank u for ur reply , i guess im gonna have to start with the switch itself and work my way down. hi speed works just fine itll engage "on the fly'. so must be something small .
Old Aug 21, 2007 | 12:58 PM
wendell borror's Avatar
wendell borror
A comon problem is the electric shift motor on the t-case. 4 low is the least used so it can stiffen up where the shift motor can have trouble engaging it. I run my truck in both ranges at least once a month, even if it's just to the barn and back.
