Dana 60/44?
Old Aug 13, 2007 | 09:51 PM
drews_79_ford's Avatar
drews_79_ford
Dana 60/44?
Ive got a 79 f250 camper special and was wondering if the front diff is a dana 60 or 44? At first I thought it was a dana 60 but I read about trucks from 1979 and saw that they came with dana 44's and that the dana 60 was an option. I tried looking up the serial number and it said the day it was made and what motor ect. And I was just wondering how you identify differentials.
thanks
Old Aug 13, 2007 | 10:42 PM
JBradley500's Avatar
JBradley500
i think the easiest way is to measure the hub....if its 4" its a 60, if its smaller then it would make it a 44.
Old Aug 13, 2007 | 11:41 PM
RNOVRIT's Avatar
RNOVRIT
On the webbing of the differential housing it should have a "44" or "60" cast into it.
Old Aug 13, 2007 | 11:54 PM
Mil1ion's Avatar
Mil1ion
as much as some people hate to hear it.
The best info is in the specific systems forums.
ITC,the "Drivetrain forum"
Hope this helps.
Old Aug 14, 2007 | 03:58 PM
75F350's Avatar
75F350
You know that you have a 60 in the rear. Simply use it as a reference to size up the front one.
Also, easiest way to tell is by the size of the inspection cover bolts. The 60 will require a 9/16 wrench, or socket, and the 44 only requires a 1/2 inch.
Simple, and works every time.
