fuel filter
Old Aug 13, 2007 | 07:03 PM
COLEnMICHAELS66's Avatar
COLEnMICHAELS66
fuel filter
i was doing some routine maintance on my explorer today and i was going to replace the fuel filter and realized i couldnt find it! any clues on where it might be. its a 2002 Explorer with the 4.0 SOHC 4x4 and 5R55W tranny.
Old Aug 13, 2007 | 07:25 PM
super 6.8's Avatar
super 6.8
Passenger side tucked up above the frame right about even with the doors. Just follow the fuel line and you will find it. It is not the easiest thing to change, but not all that bad.
Old Aug 13, 2007 | 08:29 PM
COLEnMICHAELS66
cool. from the looks of the new filter i'll have to use a quick connect tool to get the fuel lines loose. is that correct?
Old Aug 14, 2007 | 07:46 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
That is correct and be sure to depressurize the system before changing the filter and also wear goggles to protect from any gasoline that may squirt out when removing.
Old Aug 14, 2007 | 08:53 AM
quicklook2's Avatar
quicklook2
if you do not already have one, purchase a repair manual.
it will help you do things like this and save a ton ogf money in the long run.
